daipower wrote:yes but it doesnt come back on.
ake wrote:The earthed relay switch wire comes from the engine ecu (PCM), as does the control wire for the fan.
The low pressure switch is also connected to PCM, via two wires, which both have to go to earth to run the AC.
If you want the wiring diagram, then let me know your email address
daipower wrote:Geoff,
No I havent, I was hoping to get it sorted on here. I think its a bad earth and the relay voltage is low and dropping out.
Dai
flashy wrote:daipower wrote:yes but it doesnt come back on.ake wrote:The earthed relay switch wire comes from the engine ecu (PCM), as does the control wire for the fan.
If you want the wiring diagram, then let me know your email addressdaipower wrote:Geoff,
Dai
My air con was working fine until the pcm gave out, I had it replaced & that's when my air con problems started. The high pressure switch has four wires going into it only one is showing power is this normal? A copy of wiring diagram would be great.
