daipower wrote:I have two fans, both spin as soon as i turn on the air con.
daipower wrote:Lads,
I think I have cracked it. I ........After a while tonight I noticed that only one fan was working which got me wondering if the box could see the voltage from that fan and in turn switch on the air con clutch. I got a battery and connected it direct to the van no joy, fan wasnt working. ......
thanks for the help on here
Dai
Altransit wrote:What function does the smaller fan on the drivers side have If the passenger side (larger) one does the aircon coolng, does the other one do the engine cooling
I'm pretty sure now, having looked at it carefully, that the fan I have, does both jobs, so maybe it's the higher engine outputs that need the twin fans
My sons' TDCi Focus has the same single fan and controller (same part number too) and his aircon works just fine.
I'll try bridgeing out the relay, but I could feel the contacts opening/closing when I removed and refitted it whilst the engine and aircon was switched on, but I am hoping that the compressor not kicking in is an electrical problem, rather than a knackered unit
Thanks for your input
andz327 wrote:Altransit wrote:What function does the smaller fan on the drivers side have If the passenger side (larger) one does the aircon coolng, does the other one do the engine cooling
Yeah my mk7 130 has twin fans
andZ3 Sony Z3
I think I have cracked it. I sat down with the wiring diagram after reading the posts on here. Some time ago I managed to buy a secondhand rad with twin fans and control box. I took the control box off that rad and tried it on my van, still the same problem. After a while tonight I noticed that only one fan was working which got me wondering if the box could see the voltage from that fan and in turn switch on the air con clutch. I got a battery and connected it direct to the van no joy, fan wasnt working. I then went to get the secondhand unit, I unclipped it from the rad and took it over to the van and plugged it in. Hey presto, aircon working again as it should.
So, if one of your fans isnt working, the aircon stops. Probably a check to start off with as its far easier to check than pressure sensors etc. I now have a spare rad with twin fans, the one on the right as you look at the van from the front isnt working, but the box of trick etc is.
Of note, the box of tricks is 940 085 00 and the original one was 940 043 00 in case your trying to get a seconhand one.
I hope this is the same fault for you guys, I am sure its not much to get a fan motor recond.
Let me know how you get on, this did my head in and I am so chuffed tonight.
Dai
Altransit wrote:Yes, the clutch isn't engaging, and pressing on the front pulley when its running and the A/C turned on, just produces a whirring noise, so it may be that the solenoid is not working, or there is no power to the solenoid for whatever reason.
The solenoid seems to be powered directly from the relay R10, but according to the diagram that Loot has sent me, it earths via a "Heater bypass vacuum controlled valve solenoid" and a "maximum cooling mode switch" whatever and wherever those components are
If I could get at the (very inaccessible) wiring connector, I could try powering it directly and see if the clutch then engages.
It's fun this investigation lark
andz327 wrote: Altransit you can get to the pump wires under the air filter box to check or run feed to pump
Altransit wrote:andz327 wrote: Altransit you can get to the pump wires under the air filter box to check or run feed to pump
Indeed, since that post I've power probed the compressor, and it's officially dead, and awaiting replacement
Youngest son's Focus turned out to be a dead fan controller, and also a dead compressor, which has now been replaced under warranty
bambi mk 1 wrote: Wish you luck changing it Al
bambi mk 1 wrote:Change the ac tensioner and belt when your at it
Altransit wrote:bambi mk 1 wrote: Wish you luck changing it Al
I've already looked and I'm not going there My tame local garage has quoted me £150 plus to change it and degas/regas, and I trust their work
I'll ask about them doing this as well, got any part numbers
