Hi all, a quickie and I'm sure an easy one for you lot. I turn the key in the ignition, I hear a click but no starting. Turn off, try again and it starts ?. could this just be dirty / indifferent connections somewhere ?. MK3 1988 2.5
I would suspect starter solenoid contacts on the starter motor but first make sure battery is fully charged and can deliver the cranking power needed . Than check for corroded or lose wire connections . Cheers, Andrei
