andz327 wrote:Is it still not starting
andz327 wrote:Be sure the flywheel pin is in the right slot as there's plenty of slots your pin can go in if its not the proper pin
martynx wrote:Maybe no fuel is getting to the injectors ? Fill up fuel filter , crank for 20 seconds , refill fuel filter..& repeat a few times should help purge or rule out air in the injection system..you could undo feed pipes to injectors , at the injectors, also while you do it then you'll see if fuel is getting there or not... if that doesn't get fuel flowing connecting a pipe directly to the pump & pouring a bit in there works sometimes..
andz327 wrote:But I could be wrong, I've lost the place with this one so dread to think how Ronnie feals
andz327 wrote:Does it start off the key now?
andz327 wrote:Any joy Ronnie?
