Need to replace ignition switch (Mk5). Does the barrel have to be removed or does the switch simply pull out?
Cheers
ake wrote:Switch is held on with two grub screws, no need to touch the barrel
Frag wrote:Very small flat blade,they are recessed into housing but don't need to be removed completely,
Just slackened enough to release the switch.
If you put your head down into footwell and look up you will see them..
