Hello all,
New to this forum, but hoping you nice folks can help me out of a bit of a pickle.
Here at the Wells and Walsingham Railway, we have a small Diesel Shunting Locomotive that is running a 2.5 DI (non turbo) "banana" engine through a hydraulic drive.
The engine has been fully serviced with fresh antifreeze, new temperature sensor, new thermostat, fresh oil and new filters all round.
However we are having a problem with the engine running very hot. It has yet to actually boil over, and there is no sign of damage, but the temperature gauge (which has been verified as accurate by dunking the temp sender in a freshly boiled cup of water), says that on warm days the coolant is reaching 120 degrees.
I have heard that these engines do tend to run hot, but can't find any info on how many degrees is too hot?
The engine has a large radiator with fan of about a meter square providing the cooling, but the problem is that the locomotive only ever does a maximum of 9 miles an hour, so the airflow over it is never going to be as much as if the engine were fitted to a transit as Ford intended! This is made even worse when the loco has to run backwards, since there is only a radiator at one end.
As well as finding out the safe temperature limit for the engine, I could also use some ideas for how get the engine to run cooler, preferably without spending mega-money significantly redesigning the cooling system if at all possible.
Is there a thermostat that opens at a lower temperature available for these engines?
thanks in advance
TJ
