DodgeRover wrote:There may be an alloy tag on the differential cover (looks a bit like a frying pan on the back of the axle) giving the axle ratio. If you are happy with the way it goes up hills and down the motorway then get a replacement axle with the same ratio.
ake wrote:You may be able to repair it, find a tame mechanic
