I have a Mk7 2.2 85PS which had rough idle and occasionally went into limp mode which I cleared using Forscan on my iphone.
I have replaced the PRV and the SCV and done the Pump Learn, but when I try the Pilot learn it fails part way through saying that the required vehicle parameters can't be met. There are no faults showing at the time, however, the cylinder balance readings are all wildly different ranging from+1.7 on cylinder 2 to -1.1 on cylinder 4. Would this stop the pilot learn from completing and if so what is the likely cause? Not injectors I hope.
If I can get this sorted, would I still need a PCM update?
Thanks.
Dave.
