Hi there,
My name is Sebastian i live in the Netherlands and I'm new to this forum.
Since to weeks i own a 2001 Transit 2.4 tddi 90hp with 5 speed auto shift gearbox.
After a couple of days the problems started.
If i hit the brakes and it has to backshift in fourth gear it sometimes rubs its teeth and shift into neutral and finally ends up in fourth gear with the light on the dash flashing.
It's very bad when i leave the motorway and slowly reduce speed by lifting the gas.
The same teeth rubbing happens sometimes if it shifts up into fourth gear.
If i put it in manual and downshift when the engine has low revs i don't have the problems.
Also in manual when shifting up from third to fourth gear the problem is less when i lift the gas and shift manual.
I think the clutch is not very good because i can smel it if i have to drive away on a slope. Can that be the problem?
Maybe it's very bad and the clutch can not come to a full release when shifting to fourth ?
Since i don't have any knowledge about this gearbox i hope there is some experience here.
The clutch oil level is ok, i also replaced the black and grey relais under the bonnet.
Regards Sebastian
