by Lpgc » Fri Sep 16, 2016 12:13 pm
I'm in Yorkshire, about equal distance (10 miles) between Doncaster, Pontefract, Wakefield and Barnsley, 2 miles from the A1.
Very unlikely your problem is due to blocked filters. I have repaired thousands of LPG installs, factory fitted and aftermarket, and out of all those only a couple had trouble due to filters! If filters were a problem would expect the van to idle OK but get progressively worse as engine output was supposed to rise (more you put your foot down, and especially at higher rpm, the more gas needs to flow through filters so a restriction becomes more of a problem), but even then it would be unlikely filters were the problem...
If your system is factory fitted and Transit model isn't a Connect it will be the usual Nikon Koltec factory fit stuff as also fitted to Vauxhalls etc. When I say 'usual', actually there's a bit of difference in components between the Transits and Vauxhalls, especially with the electronics but also with other parts that you might otherwise think were interchangeable such as the fuel distributor/metering unit.
There are many potential problems that could cause your symptoms... Lambda probe, failed reducer, incorrect reducer pressure, failed distributor/metering unit, ignition system problems, EGR problems. Far less likely but possible electronic parts such as the rpm filter.
I've had a bit of a look around on this forum and have yet to read from anyone else who seems to understand these systems. Recently a member of this forum posted on LPG forum offering his expertise at repairing one of the electronics units fitted as part of Transit factory LPG systems - He didn't even seem to know that the LPG system uses lambda input, it is by no means certain that the Transits he believed he'd previously sorted by 'fixing' RPM units were actually caused by faulty RPM units. Your particular problem is very likely not to be due to a failing RPM unit.. because your van seems to at least run on LPG...
As said, there is no such thing as a service manual for any factory fitted LPG system.
The petrol diagnostic socket is not associated with the LPG system, you cannot pull error codes associated with running on LPG from OBD2. Some people fall into the trap of trying to use OBD2 to determine problems on LPG and are surprised when live data on lambda readings etc seems to check OK. What they don't realise is that the petrol ECU is fed dummy values while running on LPG, the dummy values always show correct running except sometimes informing on thingslike misfires (Transit systems use a slightly different approach but this is all still strictly true).
Some Nikon Koltec systems (Vauxhalls) have a very simple type of diagnostics built in - but too simple to be useful, better off with a multimeter if you know what you're doing.
A lot of people claim to know how the systems work, especially among LPG installers, but the best most can do is change filters and try swapping in new parts... That kind of approach is almost certain to lead to a more expensive repair (or more likely expense without even managing to repair) than by someone honest who knows what he's doing, especially if the others don't know that even all new parts might not work properly out of the box because the system needs to be calibrated properly too.
There are too many iffs / buts and possible combinations of minor issues that could add up to cause your problems for me for to write a diagnose / repair manual and if I did it would mostly benefit my competition! You haven't said much about how your van drives on LPG - Does it misfire / you say it seems lean? Under what conditions? How does different throttle/rpm seem to effect it? Connect a multimeter directly to lambda signal voltage (meter in van beside you connected to lambda signal and battery earth with a long bit of wire) - When you drive and engine isn't misfiring, what happens with lambda voltage under different throttle/rpms etc? Make sure the voltage keeps shifting while you drive on petrol too...
Got to be said that there comes a point with factory fitted LPG systems that repairs are not really viable - E.g. If system needs a new reducer or other expensive part it can be better to replace the old factory system with a brand new aftermarket system that will be warranted etc. Parts for Nikon Koltec systems can be much more expensive than the equivalent part for an aftermarket system, not all parts necessary for Koltec systems are even necessary for aftermarket systems... No RPM filters, no relays, no OBD emulators, etc. WOuld be a shame to buy a new expensive Koltec component even if the component fixes the running on LPG if 2 weeks later another expensive Koltec component fails - then would be wishing had fitted a new aftermarket system which might have cost less when all said and done.
Simon
