by MinorMatt » Wed Sep 14, 2016 9:28 pm
Where the front and rear half of the casings join together? Get a seal kit and thats a fairly easy fix.
The common place to leak is the seal that holds the hall sensor in (its known as the square seal - try doing a search). Its the sensor on the engine side of the pump - the pump needs to come off to fix it
www.facebook.com/transitionclassicsLucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
