Hello.
Firstly I apologise for becoming a new member mainly just to (hopefully) pick your brains, but I've a problem with a Transit motor that, despite much research over the past few months, I don't see that anyone else has had and I've now reached a stage with fault-finding that I could do with some help with.
Also, just to make it worse, this motor isn't even fitted in a Transit! I just hope you can forgive me enough to maybe assist with the puzzle.
The vehicle is a 2013 LR with the 2.2 TDCi Transit motor that has done around 30k miles. I purchased it in not going condition so I'm not completely certain what happened before but I've spoken with the previous owner and according to him it just stopped while driving along and failed to start again. Apparently there was no prior warning of a problem, although a few miles before he'd been through a bit of water (not enough to come anywhere near drowning it, and the motor was running fine during and after).
The symptoms I currently have is that it will turn over at around the right speed, compressions sound fine, there are no warning lights, and the ECU seems to be doing everything else fine, but it just won't start.
However it will backfire - loudly - and even kick-back occasionally. Personally I've never before had, or heard of, a diesel backfire myself, but it's clearly possible!
I've scanned for codes, it did have a CKP fault code and so I replaced the sensor with a genuine replacement, unfortunately to no avail. Prior to this I had cleared the code and tried again - the fault code never returned but I replaced the sensor anyway since it's clearly involved with timing (which seems to be the issue in my view).
I have also replaced the fuel, checked the cam sensor (on a 'scope), checked air filter etc etc - all the usual stuff - but nothing has made a difference. I've a new cam sensor on order just in case but I don't really expect it to make a difference at this stage. Fuel pressure is ok from what I can tell.
Anyway if you think it seems odd then hang on 'cos it gets odd-er... it
has actually started twice for me BUT on both occasions it appeared to exhaust through the air intake (quite a lot of smoke which I assumed to be unburnt fuel from lengthy cranking with no start ejecting out of the intake grill). The start occurred directly after a kick-back and so I have assumed that the motor was running backwards. It ran for just a few seconds and then stopped, the tachometer was showing around 1500RPM (in the right direction!). Frankly if I hadn't seen this myself I'd find it difficult to believe, but I did see it, it did happen. I do wonder if in fact it was turning the right way and there's somethng up with the EGR valve but with the backfiring, kicking back etc I keep coming back to it running in reverse - and no I didn't try putting it in gear to confirm
So my conclusion is, as I've alluded to before, that it's a timing problem... but the components appear fine, the CKP mount is not damaged, the flywheel looks fine (from what I could see using a borescope to look at it), it turns over evenly, and there is just nothing physical to suggest anything awry so I'm somewhat puzzled.
I'm now very reluctant to carry on turning it over because it could damage something (the kickback and backfiring can be quite severe), but naturally I'd really like to get it going.... so i was hoping someone may be able to help me and perhaps have some ideas as to what might be at issue?
Thanks, P.
