Hi all,
New here and in desperate need of help!!
I've just bought a Mk 6 2.0 TD crew cab but it has an odd engine fault...
At any speed it occasionally, and sometimes often, cuts out, the glow plug light flashes and if I turn the key off and on again it restarts without any problems (either by bumping or with the starter motor).. This only seems to happen at low revs, if I keep it revving it's fine, if it's idling in traffic it's fine. It does seem to be a little worse as the van warms up but this may just be my imagination!
If anyone has any idea where I should start looking for this I would be hugely grateful, I've only ever worked on petrol engines so this diesel is going to be a big learning curve!!
Many thanks.
Paul.
