by transom » Fri Oct 21, 2016 11:29 am
Hi all, I'm at my wits ends with this. It started about 6 months ago and has got progressively worse.
It always happens 1st thing in the morning whilst driving at low speed and changing gears. It is a loud clicking noise coming from gearbox, flywheel area. Once at high speed i.e on the motorway its fine. It will then start again from starting, traveling around at 30 -40 mph. It was initially doing this maybe once or twice a week, it's now a daily thing. I have been to my mechanic, who suggested he change the viscous fan, still the same problem. I then began having trouble starting, put a new starter on. It now will not start sometimes, it will take 3 - 4 attempts. Went to a local specialist in gearboxes, flywheels. They couldn't diagnose it.
I had the solid conversion fitted about 3 years ago as this was recommended, the specialist are now saying they will not fit solid flywheels and have reverted back to dual mass. Could it be a problem with the solid flywheel ? I don't really want to go to the expense of putting a dual mass back on, and this not be the problem !!
Is it worth going to FORD to see if they can diagnose it ?
Any help would be greatly appreciated.
Many thanks.
Tom.
