VJ 6 Aus wrote:If its a RWD YOU DON"T NEED TO REMOVE THE DUMMY/HALF SHAFT to change the disks just undo the 5 TX 50 bolts thru the disk and hub you will need a long torx socket or a long torx bar and a bit of pipe for leverage and off comes the whole hub unit
nascar wrote:its the front wheel drive, drive shaft nut, the one in the middle of the disc.
gemini wrote:100 T280 wrote:Hub nut torque is 200Nm, (I believe nut is a 36mm)
is this the halfshaft retaining nutif it is the torque is 400Nm
