Temperature Sensor
Temperature Sensor
Postby Jaydensdaddy2009 » Sat Nov 19, 2016 8:13 pm
Hi all I have a 2008 mk7 transit 2.2 fwd Swb. I would like someone to help me locate the temperature sender. I have just had new genuine thermostat and housing fitted as my temp would start moving up from cold but then would go back down then get to half way and stay there. Someone suggested thermostat but it's still happening so I think it could be the sender switch now but can't locate the it. Thanks.
Jaydensdaddy2009
Re: Temperature Sensor
Postby knobby1 » Sun Nov 20, 2016 11:43 pm
Jaydensdaddy2009 wrote:Hi all I have a 2008 mk7 transit 2.2 fwd Swb. I would like someone to help me locate the temperature sender. I have just had new genuine thermostat and housing fitted as my temp would start moving up from cold but then would go back down then get to half way and stay there. Someone suggested thermostat but it's still happening so I think it could be the sender switch now but can't locate the it. Thanks.
They don't have a coolant temp sensor as such...they do have a cylinder head temp sensor....See here #6G004, Pn: 1770525
http://www.catcar.info/ford/?lang=en&l= ... I1NzgrMTMz
If you're getting fluctuating coolant temps, I'd suggest you have a look good at the waterpump/PAS drive, they have a habit of dying on the FWD machines if they have a few miles on.
Postby andz327 » Mon Nov 21, 2016 12:06 am
They sit halfway as normal , if you're turning your heater on before it reaches halfway may stop ir heating up properly in cold weather
andz327
Postby Cellutron » Tue Feb 14, 2017 10:53 am
Hello
Interested to see if the original issue was resolved in the end!
Is the water pump/pas failure manifested in temperature guage fluctuation?
What could cause the guage not to move at all, with ignition on or engine on or even when engine is warmed up?
Grateful for any suggestions!
Cellutron
Postby andz327 » Tue Feb 14, 2017 7:58 pm
Hello
Why whats your problem??
andz327
Postby Altransit » Wed Feb 15, 2017 11:28 am
See here ......................
:arrow: viewtopic.php?f=5&t=154775&p=1343685#p1343685
Postby andz327 » Wed Feb 15, 2017 7:26 pm
Altransit wrote:See here ......................
Ta much
andz327
