Battery draining issues - could it be the parrot bluetooth?
Postby joejoyce79 » Tue Nov 29, 2016 11:50 am
Hi folks,
I bought a 2005 transit MWB medium height just over a week ago from a main dealer - before I brought it home it had all it's service and mot etc and they put a new battery on it. When I got it home, I didn't drive it for a few days (less than a week) went to take it for a spin only to find the battery is completely flat?? not what I would expect from a new battery and even the central locking has given up it's that flat!! - but the only light still on is that on the parrot bluetooth even with no key in the ignition - just wondering if this has happened to anyone else before and whether it's likely to be that? I've read of people installing them incorrectly on to main electrical feeds etc
So I'm thinking of uninstalling it anyway before trying to boost my battery to see if it is this - any advice on how to get it out and what I may need to be careful around...thanks in advance (total novice and new to ford transit vans!)
joejoyce79
Re: Battery draining issues - could it be the parrot bluetoo
Postby amlav » Fri Dec 02, 2016 5:13 am
quite unlikley that your bluetooth parot drained the battery . It must be something else there in my opinion .
amlav
Postby Dodge20 » Fri Dec 02, 2016 9:37 am
I had a car years ago that kept draining the battery, it was a stuck relay. The relay was slightly warm to the touch could be worth checking all the relays.
Some people are like slinkies.... not good for much but bring a smile to your face when you push them downstairs.
2009 280 85hp
2015 290 Custom DCIV twin side doors 155hp(tragically killed)
Dodge20
Location: Go to the end of the world and turn left. (South Cumbria)
Postby blue estate » Fri Dec 02, 2016 9:59 am
Check the load area lights are switching off
blue estate
Postby angusp » Fri Dec 02, 2016 7:51 pm
My parrot switches off with the key, so something wrong there anyway.
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
