chris72a wrote:Hey All, so I have one main stereo in front and a second stereo in back with separate speakers is it possible to hook up both stereos and speakers to the AMP considering only one will be switched on at any given time, the amp is powered off the main battery but the second stereo is powered off the leisure battery so may have to rethink this.
Many Thanks
Chris.
C'mon Chris....
Thought you had all this sorted the other day when you were at my place...
I think you should be able to do this if your amp has dual inputs, I think some of the later/higher spec amps also have bluetooth, (not too sure though), so you may be able to run them both as a single unit via bluetooth...? Or...you can run both units to a switchable link and use either/or...when driving you can switch to the front unit, when lounging around in the back, switch to the rear unit.....just thinking out loud here...
Lord Knborot
