mtbcol wrote:Hi ake
No, hazards only work on one side (left) as well. I think the "squeaking" was is coming from under the drivers seat? if that helps.
I'm going to start pulling out lamps from front and rear R/H indicators tonight. Does the side repeater (near the mirror) have a separate bulb or is it a sealed unit?
So just recap, if I pull out a faulty lamp It should cure the problem and I assume replacing it with a working one will do the same
Really hope it is going to be this simple
Thanks again, will let you all know tonight. New learning curve for new van
Colin.
