APH wrote:Glad you got it running, and agree it probably needs a good bast out and run up to temp to clear all the tubes etc
However, must have been fuel related for the non start, as they will start without crank sensor working / plugged in, just won't run for more than about 3 seconds.
Andy
andz327 wrote:APH wrote:Glad you got it running, and agree it probably needs a good bast out and run up to temp to clear all the tubes etc
Andy
Without crank sensor it'll only start with easy start , after doing his cylinder head and setting timing up, when puting the sensor back in it most probably needed shoved in a bit more which is very common
bambi mk 1 wrote:andz327 wrote:APH wrote:Glad you got it running, and agree it probably needs a good bast out and run up to temp to clear all the tubes etc
Andy
Mk 6 will start and run for 3 secs approx with duff or disconnected crank sensor
