by loot » Sun Feb 12, 2017 9:59 am
Have you checked the fuel filter and filter head and ignition switch also? Have you had codes read? I personally haven't had a non run situation related to the pump or valves yet so I'll say it is usually air in fuel or electrical problem, checks needed to diagnose in any case.
Mk7 don't generally need a fuel pump replaced, especially without extensive diagnosis first.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
