LED headlights bulbs-DON'T DO IT.
Postby Mike » Thu Feb 16, 2017 10:05 am
There have been a few threads here recently about the use of LED headlight bulbs, H7/H15 in the Custom and H4 in the MK6/7.
There has been ZERO positive feedback. Due to the way LED's work, there isn't (yet) a way of getting a decent beam in a reflector OR projector headlight unit.
Your legal options for decent MK6/7, Custom headlights are either Philips X-treme Vision/Racing Vision or Osram Night Breaker Unlimited/Laser.
Non legal options for the MK6 are an H4 HID kit from HIDS4U, this works very well. HID kits also give a very good beam in the Custom with projector lights (Trend, Limited and Sport), but later vans (2015 on?) seem to have issues with the BCM cutting power to the HID's.
MK7 lights don't give worthwhile results with HID kits.
There could be a light at the end of the tunnel for the MK6/7 and other H4 bulbs users though. Philips have developed an H4 led, the X-treme Ultinon LED, but it's not available in the UK yet. Don't confuse the genuine Philips LED offerings with the ones that use Philips LED chips, Lumiled for example ARE NOT Philips bulbs.
Mike
Wind up merchant!
Re: LED headlights bulbs-DON'T DO IT.
Postby andz327 » Thu Feb 16, 2017 11:52 am
Nice price fookImage
andz327
Postby seikokid » Sat Feb 18, 2017 5:46 pm
i did check out these http://www.horizonleds.co.uk/exterior-l ... 000-lumens which i have bought and fitted them - getting intermittent dipped beam fault and when i installed the separate decoders it made no difference
i've since turned the lamps 90 degree and now the left side is perfect . just need some minor adjustment to the right
seikokid
Postby seikokid » Sat Feb 18, 2017 5:51 pm
until now i was using Osram night breaker and sometimes wasent sure if my lights were even on. On dark roads had to use main beam or supplement with the fogs.
seikokid
Postby seikokid » Fri Mar 03, 2017 7:17 am
Improvement i feel on the left but cannot get the right to play ball. ?
seikokid
Postby Mike » Fri Mar 03, 2017 9:57 am
In the last pic it looks like the hotspot is almost upside down? Can you spin the bulbs while they're in the light and switched on?
Mike
Wind up merchant!
Postby andz327 » Fri Mar 03, 2017 12:53 pm
£150 and still can't get decent beam image...fook that, think I'll stick with
£10 130/90 Ring sport h4s
andz327
Re: LED headlights bulbs-MAYBE DO IT.
Postby Mike » Mon Jan 22, 2018 12:04 am
Now available, in H7 and H4 https://www.powerbulbs.com/store/catego ... nd/philips
Mike
Wind up merchant!
Postby adam75pl » Mon Jan 22, 2018 8:25 pm
Not road legal...
This post only expresses opinion of the author of today. It can not be used against him tomorrow, or any other day following that date. In addition, the author reserves the right to change his views, without prior notification.
T280 SWB 2.2 115PS
adam75pl
Postby paul2012 » Mon Jan 22, 2018 9:01 pm
adam75pl wrote:
Not road legal...
I noticed that too. Although no surprise as 6500K is daylight. (
Hell of a price to pay for off road use only bulbs.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby MinorMatt » Fri Jan 26, 2018 11:54 am
Just a word of warning guys...
It seems that retro-fitted HIDs will me a MOT fail as of march/april this year. I don't think LEDs are yet - but its entirely feasable they will be in the not too distant future!
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Mike » Fri Jan 26, 2018 12:54 pm
MinorMatt wrote:Just a word of warning guys...
Thankfully I don’t have to frequent mot places and put up with surly grease monkeys :mrgreen:
Mike
Wind up merchant!
Postby Punto443 » Wed Jan 31, 2018 8:54 am
Also a word of warning regarding retro fitting led headlight bulbs,
They generate almost no heat and in snow etc, your vision can rapidly deteriorate as there is no heat to melt the accumulating snow.
As I found out the hard way! Having to stop on dangerous situations to clear it every few miles :?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Altransit » Wed Jan 31, 2018 10:46 am
Punto443 wrote:Also a word of warning regarding retro fitting led headlight bulbs,
Yep, we now need heated light lenses, as well as heated side windows :P :mrgreen: :wink:
Postby Mike » Wed Jan 31, 2018 3:09 pm
The Philips bulbs have fans fitted to them to dissipate the heat :?
Mike
Wind up merchant!
