dumper wrote:My last mk5 had 98000 mls on it when I got it & 180000 mls on it when I sold it in that time it had oil and filter every 5000 mls fuel & air filter every 10000 mls cambelt kit at every 40000 mls.two water pumps the last pump and bent kit was put on for the new buyer the only outher parts I fitted to it where alternater/vac pump. I also blocked off the egr removed control rod and cleaned out the inlet manifold .the only bother I had on the road was when the alternator whent ana a misfire Whitch was only needed the injector pipe leak off mod doing .my van had the Bosch fuel pump but I think the epic pump can have a few more problems.the di is probably the best Diesel engine Ford ever did .
As above.Regular servicing and they just keep on going.
My Mk5
Last one I had did nearly 400,000 miles before I had to get rid (due to tin worm)
Head gasket went @ 250,000 miles
