MK5 Cracked head problem, other issues
Postby Scrambler » Tue Feb 21, 2017 10:05 am
Hi everyone,
bought a transit supposedly blown up (cracked head apparently) the alternator was missing. I have since sourced an alternator for it but I really need to find a Haynes manual pdf format preferred or at least a parts catalogue where I can see a break down of the alternator and bolts etc
any help appreciated
Scrambler
Re: MK5 Cracked head problem, other issues
Postby dumper » Tue Feb 21, 2017 5:38 pm
I have never had a cracked head on a DI but have had cracked pistons
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby knobby1 » Tue Feb 21, 2017 7:56 pm
Scrambler wrote:Hi everyone,
Is this what you're after..??
http://catcar.info/ford/?lang=en&l=bWFy ... NCsyNzI%3D
http://catcar.info/ford/?lang=en&l=bWFy ... I3Mg%3D%3D
Postby Scrambler » Wed Feb 22, 2017 10:22 am
Ahh! Thats exactly what I'm after, thanks for that. So the engines in these things are quite reliable? I've heard conflicting things. No pdf workshop manual some where?
Scrambler
Postby dumper » Wed Feb 22, 2017 11:08 am
My last mk5 had 98000 mls on it when I got it & 180000 mls on it when I sold it in that time it had oil and filter every 5000 mls fuel & air filter every 10000 mls cambelt kit at every 40000 mls.two water pumps the last pump and bent kit was put on for the new buyer the only outher parts I fitted to it where alternater/vac pump. I also blocked off the egr removed control rod and cleaned out the inlet manifold .the only bother I had on the road was when the alternator whent ana a misfire Whitch was only needed the injector pipe leak off mod doing .my van had the Bosch fuel pump but I think the epic pump can have a few more problems.the di is probably the best Diesel engine Ford ever did .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby gotgcoalman » Thu Feb 23, 2017 5:02 pm
dumper wrote:My last mk5 had 98000 mls on it when I got it & 180000 mls on it when I sold it in that time it had oil and filter every 5000 mls fuel & air filter every 10000 mls cambelt kit at every 40000 mls.two water pumps the last pump and bent kit was put on for the new buyer the only outher parts I fitted to it where alternater/vac pump. I also blocked off the egr removed control rod and cleaned out the inlet manifold .the only bother I had on the road was when the alternator whent ana a misfire Whitch was only needed the injector pipe leak off mod doing .my van had the Bosch fuel pump but I think the epic pump can have a few more problems.the di is probably the best Diesel engine Ford ever did .
As above.Regular servicing and they just keep on going.
My Mk5 :D
Last one I had did nearly 400,000 miles before I had to get rid (due to tin worm)
Head gasket went @ 250,000 miles :o
Too bloody quiet :shock:
gotgcoalman
Postby Jim Archer » Thu Feb 23, 2017 9:01 pm
Come armagedeon the cockroaches will be driving around in DIs.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby andz327 » Thu Feb 23, 2017 9:13 pm
Cop that Di punters mk7 2.2 130hp (befire anyone else says it, I know I know it's a miracle that a 130 got past 50k) frequent oil changes with good quality oil worksImage
andz327
Postby Scrambler » Sat Feb 25, 2017 7:01 am
dang nabbit, I got a quirky alternator. Its from a 99 year and my truck is a 98 the alternator has 3 posts and 2 threaded nipples on the vac pump but my truck has a connector and one cable also I can only see one hose that fits on to the vac pump
Scrambler
Postby derv23 » Sat Feb 25, 2017 10:35 pm
Jim Archer wrote:Come armagedeon the cockroaches will be driving around in DIs.
Jim
:shock: :lol:
Scrambler , has the alt' came off a van that has a revometer ?
Does yours have a revo' ?
MK5 Tourneo.
derv23
Postby Scrambler » Sun Feb 26, 2017 9:02 am
Jim
:shock: :lol:
Well yeah I think the tach runs off the alternator too? its getting confusing now. Theres a pipe just underneath where the alternator fixes to and theres a similar pipe coming off the vac pump on the back of the alt which I assume goes to the brake booster? so where does the pipe underneath the alt go to? Then there also these two nipples on the vac pump. can it be modified to work or am I best to get the right one? Heres some pictures
Scrambler
