2005 transit common rail motor, just stops when driving
Postby kiwi » Fri Feb 24, 2017 9:29 am
2005 transit 135 common rail motor. Just stops when driving along the road, Turn the key off and you can restart it.This happen after driving about 15 miles then just stops . Question is it a computer problem
fuel , or a sencor ????? Has any body got any ideas , would like some help as we have paid the workshop once for the same problem and we are all running out of ideas.
cheers KIWI
kiwi
Re: 2005 transit common rail motor, just stops when driving
Postby ned » Fri Feb 24, 2017 9:49 am
Mk6? Tdci have you had the codes read?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby kiwi » Fri Feb 24, 2017 10:13 am
No , but will get them read next week , sat here in NZ.
kiwi
Postby bambi mk 1 » Fri Feb 24, 2017 1:17 pm
Its added extra thrown in for free with mk 6 tdci's.Stick a set of 90 badges on the doors ,stick it through the auctions turn off your phone and don't answer your door for a very long time :idea:
bambi mk 1
Postby Altransit » Fri Feb 24, 2017 1:19 pm
bambi mk 1 wrote:Its added extra thrown in for free with mk 6 tdci's.Stick a set of 90 badges on the doors ,stick it through the auctions turn off your phone and don't answer your door for a very long time :idea:
Stop it! You're depressing Ned :P :mrgreen:
Postby ned » Fri Feb 24, 2017 3:58 pm
:lol: :lol: :lol: The 125 door badge is great, at the light people think ooow that vans got power :D then you pull away and it cuts out and people then know you have a tdci :( :wink: :lol:
I dare say its going to need injectors and possibly a new pump :roll:
Bloody tdci. N
ned
Postby kiwi » Wed Mar 01, 2017 8:53 am
After getting the code read, the answer was the fuel system was loosing pressure, then the computer would cut the motor.
happen three times today,,,,, just stop turn the key to off and we can restart the motor.
Has any body had this problem , we are after comments .Thanks Kiwi
kiwi
Postby ned » Wed Mar 01, 2017 9:29 am
Yep have that problem all the time :roll: Do you know what the codes were?
Welcome to the fun world of the mk6 tdci :lol:
Check the fuel filter for swarf, do an injector leak back test. I say you'll need a set of injectors and possibly a fuel pump. N
ned
Postby Tankpants » Sun Mar 05, 2017 8:37 am
Had this problem too on a 2003 TDCI.
we've never got to the bottom of it but a couple of people suggested the fuel filter needed replacing. When I looked in the owners manual about fuel filter it pointed me in the direction if a device under the bonnet to test the filter. In a nut shell, to use this device to test the filter you have to run the van, in neutral, at full revs for 3seconds. That was a long 3 seconds!! I thought the engine was going to explode!! Anyway, tester indicated that filter was OK and since then van has run ok. It's almost as though there was a bit of crap somewhere in the fuel system and revving it's nuts off cleared it away.
Might be worthy checking your fuel filter before spending out on injectors which will cost hundreds.
Good luck!
Tankpants
Postby ake » Sun Mar 05, 2017 6:26 pm
kiwi wrote:After getting the code read, the answer was the fuel system was loosing pressure, then the computer would cut the motor.
It needs injectors, they always do.
The leakback will be excessive causing the low pressure
Postby kiwi » Tue Mar 14, 2017 8:46 am
Been in the workshop , replaced c/rail // mettering value ///injectors// drain tank and replaced filter // new pump//client gets transit back , drives like a rocket , hes happy... But wait theres more , packs up motorhome to go to rally,,. goes good for the first mile , hits a little hill and lost all power. stops , turns key of and on and restarts ,,, and ,,, back to normal ... goes to rally and after two day go to start transit and it is running on Two cylinders ...back on the brake down truck and to the workshop again.. ANY IDEAS OR COMMENTS
kiwi
Postby wojciech » Tue Mar 14, 2017 2:17 pm
It is not... correct answer. :roll: What errors have you?
If injectors are worn-out, it is error P0251, or P1211 or both.
Check IMV valve on injection pomp with working engine. You need good tester (IDS) and good diagnostician. You drive van, diagnostician keeps IDS laptop on his knees and looks for rail pressure. Standard procedure.
wojciech
Postby bambi mk 1 » Tue Mar 14, 2017 8:23 pm
kiwi wrote:Been in the workshop , replaced c/rail // mettering value ///injectors// drain tank and replaced filter // new pump//client gets transit back , drives like a rocket , hes happy... But wait theres more , packs up motorhome to go to rally,,. goes good for the first mile , hits a little hill and lost all power. stops , turns key of and on and restarts ,,, and ,,, back to normal ... goes to rally and after two day go to start transit and it is running on Two cylinders ...back on the brake down truck and to the workshop again.. ANY IDEAS OR COMMENTS
You didn't listen to me did you :wink: It will do your head in :(Was there filings in the injectors :?:
bambi mk 1
Postby knobby1 » Tue Mar 14, 2017 8:56 pm
bambi mk 1 wrote:Was there filings in the injectors :?:
Probably the whole fuel system needs a flush out if the pump was duff, including tank, filter head and all lines etc.. :?
Postby kiwi » Sun Mar 11, 2018 9:10 am
In march 2017 this 2005 had new pump new injector and has been running ok, until it started to miss fire, re two of the new injectors because the ohm reading were all different. start transit go to Rally , stay the night, start transit run of the blocks turn motor off. Restart motor and it missed fired , then stopped . I restarted it and it miss fired again. Now the engine will not start and is on the Back of a transportor of the the Mechanic. Please can any body have any ideas , just about to sell this thing. IT was a nice motorhome 2005 135 common rail motor.
kiwi
