darrenmk7 wrote:Hi all the bearing in my clutch is making a noise when i press the clutch pedal is goes i have had a quote for clutch kit and the bearing replaced and clutch as the gearbox will be removed might aswell have a new clutch came in at £700 what do you guys think?
darrenmk7 wrote:reckon i will be getting a few quotes
darrenmk7 wrote:fwd typical why is it more involved?
Brains_transit wrote:darrenmk7 wrote:fwd typical why is it more involved?
You need to remove the driveshafts which is involves removing the bottom balljoints on both side and the gearbox oil then comes out the holes and loosen the subframe for clearance. Rwd it's just the propshaft
