rogerw wrote:132x60=8kW about 11hp
ake wrote:Not wanting to sound negative, but the chances of a home made electric vehicle achieving two hundred miles at sixty miles per hour is about as likely as your chances of winning the lottery without buying a ticket.
Spending a no doubt large amount of money converting a van that's about 15 years old strikes me as complete and utter madness
Most of the main stream conversions use a rwd van, and ditch the engine and gearbox.
But good luck!
rogerw wrote:OP said 40 battery at 3.3v each that gives 132v , linked in series. Each batttery is 40 ah and since in series this is 40ah in total. So it's 132x40=8kw that's output over one hour.
knobby1 wrote:rogerw wrote:OP said 40 battery at 3.3v each that gives 132v , linked in series. Each batttery is 40 ah and since in series this is 40ah in total. So it's 132x40=8kw that's output over one hour.
The 40ah is a "capacity" rating, is it not??
i am with Altransit on this one.
