Ford Transit lack of power
Postby willsy23 » Mon Mar 13, 2017 9:50 pm
I have a 2.4 lwb high top transit t350 2004
van runs and drives, starts fine but has a massive lack of power.
runs on 3000 limp home rev limit and struggles up hill a lot 20 mph at most
had a new egr, dual mass sensor, fuel filters,
went to a mechanic once where he took a pipe off and it went a lot better for a little while but now back to the same,
think it was the vacuum pipe to the egr,
any ideas?????
willsy23
Re: Ford Transit lack of power
Postby andz327 » Mon Mar 13, 2017 10:26 pm
Tddi or tdci
Is it a genuine Ford fuel filter thats fitted
andz327
Postby Johnboy1234 » Sat Mar 18, 2017 4:04 pm
Fuel pump! Went on my 03 90t350, no warning lights but bought a cheap reader of eBay for about £20 which revealed various codes! It would go about 50mph but took ages to get there and only did about 20mph up hills. Had a fuel pump fitted and it was fine, could also check fuel filter, I think that can cause similar problems!
Johnboy1234
Postby robabell » Tue Mar 21, 2017 7:38 am
Have you got it sorted now?
I have a similar problem
I suspect the Turbo?
Bob
robabell
