I've just put a Di with Mt 75 gearbox in my mk1 the diff flange on the mk1 axle is the small one for a single piece prop, I had a mk2 with an mt75 and the flange on the axle is bigger and can bolt a later prop straight on to it, does anyone know if it is just a case of undoing the nut and swapping the flanges over?? If not I'll have to weld a different end on the prop.
Thanks.
