Hi All. I am fitting a head back onto my mk6 2006 2.0 125. My problem is i have chucked my old head gasket and i didn't check what notch it was I purchased a timing kit that came with a head gasket and its a 3 notch. What if the original was a 2 notch? will a 3 notch be ok?
AS far as I know the number of notches denotes the thickness of the head gasket . If head was reconditioned (shaved) than you should use the gasket with an extra notch from the original one. So if the original had 1 notch than new one should have 2 notches . But this is only if the head was reconditioned (shaved) .
