where does heater resistor go MK5
Postby wellingtondane » Tue Mar 21, 2017 9:46 pm
Hi where does the heater resistor go on a Mk5 and is it easy to change :D
wellingtondane
Re: where does heater resistor go MK5
Postby andz327 » Wed Mar 22, 2017 12:17 am
I think it's under the bonnet behind head lamp / inner wing area
andz327
Postby Keef » Wed Mar 22, 2017 12:23 am
Keef
Postby wellingtondane » Wed Mar 22, 2017 10:17 am
Thanks Keef, my new one i bought is this one, seeler said mk3,4 and 5http://www.ebay.co.uk/itm/252741161347? ... EBIDX%3AIT
wellingtondane
Postby wellingtondane » Sat Apr 22, 2017 2:03 pm
still cannot find where this goes, also how easy is it to change the heater control switch how do i get it out of the dash
wellingtondane
Postby Altransit » Sat Apr 22, 2017 3:49 pm
The resistor in the piccy above, if you have that one, will be beside the drivers headlight unit, and probably in pieces by now, but if you have a late Mk5 (1997 onwards) it could be the later type mounted in the heater box, next to the motor, and is a pig to get at!
Postby robbie.cee » Sat Apr 29, 2017 8:53 am
My resistor was up by blower motor . Could sort of see it with head on floor of van near pedal box
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
