Hi guys so about a month ago now my drivers side front brake was binding after driving for about 20 miles. It must have bean binding a bit for some time because the disk is quite worn but must of not been bad enough for me to notice. I took the calliper of and found a hole in the rubber seal around one of the pistons so I changed the calliper for a brand new one and put some new pads in and if was fine. But now it started binding again it's happening at the same point on the same journey so I don't know if it's something to do with heat ? All I can think is something gas got wedged in there but I'm clutching at straws. Has anyone got any ideas? Any help would be much appreciated
