I have a 2005 MK 6 (VJ) 2.4 TDCi that continually destroys the high pressure pipe between the pump and the common rail. It splits every time at the top connection (where the pipe connects to the underside of the rail) next to the flare nut. I'm on my 4th pipe, they last about 30k Kms. I've been told that the absence of a clip/bracket will do it but the pipe is only about 200mm (about 7-8 inches and 3 bends) long and both ends are connected to solidly engine mounted components, and there is no provision for a clip and no listing in the Ford parts book for a clip.
Does anyone have any ideas what could be causing this problem, or has anyone experienced this problem?
I can can get no satisfaction from Ford Australia. These days I buy a new one for spare each time it breaks, and have ordered a spanner that hopefully will give me reasonably easy access to the bottom flare nut. Ford parts now tell me the part is obsolete and no longer available; great.
Cheers
Kim
