Ok, for the gentleman who wanted to know the fault-codes/messages :
I only have the descriptions, not the actual numbers, as the guy that has the reader, only took the descriptions down
after a reset and a restart, it doesn't seem to give any new fault codes, strangely enough )
First one was the EGR, but we have taken that out of play, so that has no bearing on the situation (and that would have been an easy fix...when did you know that to happen !)
The second was :"Injection time, deviation from the normative/normal/regular value"
The third one was " measuring unit pump : lessening of fuel amount (signal) "
The trouble is, that we can't change that pump sensor either, just to try ...as it can't be got at without taken the engine out ....
Sad as it may be, I may end up in a Ford dealership/garage and end up with a very flat wallet.....
Paddy, unhappy and missing his van.....
PS, we double checked, there is no cabling running over/ under the start motor... it runs behind it, well away from heat and appears to be undamaged
