Can anybody give me a definitive answer on the EGR ?
If the EGR circuit is not being activated via the pcm or any other means will this affect the fuel supply in any way ? The vacuum solenoid appears to not be getting a pulsed earth and therefore the circuit is dead and the pintle in the EGR is not moving which means that there is no signal either from or to the PCM.
If the EGR circuit is not required and therefore has no ill affect on the engine why would people buy blanking plates for their EGR's instead of just pulling the connection from them?it cant just be to stop a error light.I have an issue with power loss and my EGR circuit is not working as indicated on live data, there is no duty cycle from the solenoid or EGR Valve, there is battery voltage to the vacuum solenoid and continuity back to PCM on both wires, all three wires leading back to PCM from EGR valve have continuity also
The power loss feels as if the turbo is not boosting but live data is showing 170 kpa during acceleration, theres no leaks in the vacuum and the turbo plumbing and intercooler have no leaks, the van will travel at 120kph on the highway but has slow acceleration getting there, there is no smoke visable in the mirrors while accelerating hard
Trying to find a local that has any knowledge of these vans is like looking for a snowman in the Sahara
Hopefully someone here will be able to answer this post
