nedforceone wrote:Sounds like injectors did you code them in when you fitted them.
What colour is the smoke on start up and idle?
White smoke is unburnt fuel
Blue smoke is burning oil
Black smoke is overfueling
Delphi fuel system hasn't own extra fuel pomp between tank and injection pomp. Injection pomp has own rotary vane pomp - so all pipes and fuel filter work on underpressure. Every one leakiness takes effect air in fuel.acerallyspares wrote:Is air in the system possible?
Yes.acerallyspares wrote:do you mean knock sensor? Would that cause this?
It is enough to blank it. EGR is not the cause of this problems. It is still closed now. EGR in 2,0 tdci has not sensor and PCM hasn't information about his work (position).acerallyspares wrote:the egr has a screw in it to blank it.
This symptom is always - question how sharp? In older engine it must be bigger. Evaluation is subjective. Most important is what you wrote: "I will try and get hold of a compression tester aswell".acerallyspares wrote: What would cause the puffing from the filler neck though?
No, no - injector keep tightness in head on a little steel washer on injector sprayer, not on thread in head. If injector locking sleeves is tight by correct torque (47Nm), force between little washer and head is really sufficient to keep tightness.acerallyspares wrote:when i fitted my injectors, one or two of the threads in the head were a bit dodgy. Could this cause my blow back,rough idle and smoke?
