Can I delete old key?
Postby mutley8979 » Fri Apr 28, 2017 7:42 pm
Hi
Can anyone help?
I had my Connect broken into last month at home, I presume they used a Tibbe lock pick.
I've bought a new Hykee lock for the driver's door and Armorplate lock covers for passenger and rear doors, but I don't know if they used the ODB port to programme another key so they could come back later and presumably open the doors despite there being a new Hykee lock, if you get my drift.
If they did is there a way of resetting the system so only my master remote key works as I can't afford to lose any more tools?
mutley8979
Re: Can I delete old key?
Postby loot » Fri Apr 28, 2017 8:59 pm
Ids can wipe all keys then program new :D
07 350 170ps
Ids map here
loot
Postby robbie.cee » Sat Apr 29, 2017 8:32 am
Disable the obd port!!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Apr 29, 2017 8:33 am
Get a dummy port and wire every other wire to 12v to fry their pc if they try again!!
Had
MAKE IT FIT
robbie.cee
Postby loot » Sat Apr 29, 2017 7:54 pm
Robbie i think he's worried that they've already used the obd to program a new remote, in which case until he delete all known keys then he can't be confident that they won't come along and remote unlock the doors and drive off. :wink:
07 350 170ps
Ids map here
loot
Postby robbie.cee » Sun Apr 30, 2017 8:25 am
Ah true! Still worth doing after
Had
MAKE IT FIT
robbie.cee
Postby mutley8979 » Wed May 03, 2017 8:52 pm
Hi loot
Yes you are correct, that is exactly what I am worried about.
In your first reply you said Ids can wipe all previous keys (them I would definately relocate ODB port).
Who are Ids or have I misunderstood?
Regards Martin
mutley8979
Postby knobby1 » Wed May 03, 2017 9:56 pm
mutley8979 wrote:Who are Ids or have I misunderstood? Regards Martin
It's not a "who"... it's a what..! :mrgreen:
It's Fords Diagnostic hardware/software. Many of us have "clones" of it. Where are you..?? There may be a member close by who has one and may be able to help sort you out.
Postby mutley8979 » Thu May 04, 2017 8:40 pm
Ah thanks for explaining that. I live in Cobham Surrey..
mutley8979
Postby mutley8979 » Sun May 07, 2017 2:13 pm
Hi
If anyone has the IPS software in the Cobham, Surrey area who could help me out here I would be very grateful?
Cheers, Martin
mutley8979
Postby Jim Archer » Sun May 07, 2017 5:03 pm
Vantuner is in Uxbridge.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby mutley8979 » Wed May 10, 2017 7:10 pm
Thanks Jim, I'll give them a call
mutley8979
