bambi mk 1 wrote:2011 will be a 2.2 if its a fwd.If leads don't do the trick change the electrical bit of the ign switch £15 approx.
joe bingham wrote:I have a 2011 2.0ltr . I'm having problems with starting. Ive followed the usual routes. charged battery , Ive replaced the starter. Still have the symptoms ; quite loud 'click, click, . Like several other people I assumed it was low battery / solenoid problems. Ive checked the battery , currently at 12.7 volts .and seems to be holding. Replaced the starter . Is there another solenoid in the system ? It seems to be a bit intermittent. Will start fine sometimes. other times I've had to resort to a cup pack. Sometimes with the jump ( again fully charged )pack it doesn't go , I then check connection of the neg terminal on the engine mount. - I'm not convinced this is it.
joe bingham wrote:joe bingham wrote:I have a 2011 2.0ltr . I'm having problems with starting. Ive followed the usual routes. charged battery , Ive replaced the starter. Still have the symptoms ; quite loud 'click, click, . Like several other people I assumed it was low battery / solenoid problems. Ive checked the battery , currently at 12.7 volts .and seems to be holding. Replaced the starter . Is there another solenoid in the system ? It seems to be a bit intermittent. Will start fine sometimes. other times I've had to resort to a cup pack. Sometimes with the jump ( again fully charged )pack it doesn't go , I then check connection of the neg terminal on the engine mount. - I'm not convinced this is it.
Thanks for the advice so far.Ive cleaned negative terminal. Its nice and tight . I'm a little concerned - I'd happily rush out and get the module behind ignition , But my starting issue is intermittent- always the hardest ! . What I'm finding is the following. on an occasion , no start just clicking. start with a jump pack and drive ( ten minute drive ) and stop to drop off kids etc. and then sometimes will , sometimes won't start again. some mornings it starts fine , and subsequently starts fine all day, following day , no start again. sometimes won't start after even quite a long drive. It does not seem to be related to the battery charge , the battery seems stable at 12.7 v.
My reluctance to just change module is based on finances and time, already changed starter which i didn't need to do. I'm confused, does the jump pack add an extra amperage boost ? or since the current is routed through the fuse box is that making a difference ? ( via the big red block next to fuse box )
( I have to give the jump pack back to its owner too as I've had it longer than a good neighbour should ! )
P.S. info on engine size comes from registration docs which say its 2.0 ltr.
joe bingham wrote:P.S. info on engine size comes from registration docs which say its 2.0 ltr.
