Hi guys i need some advice, been having problems starting my transit the last few months.
About 3 months ago I went to start the engine one afternoon and it just kept turning and wouldn't start I tried for ages then finally gave up, which seems odd since its always started up easily straight after turning the key. Tried again a few hours later, no luck.
Then next morning got in it turned the key and it started straight away, I then used it every day for the next 3 weeks with no problems at all until one day it would not start out side a customer's house I was parked on a hill so was able to bump start it.
And basically this has been happening frequently it works fine for 2 or 3 weeks then I get a day where I can't start it and after that it starts perfect for another couple of weeks.
Any ideas what could be the trouble ?
When it happens there's always plenty of diesel in the tank, the batteries are only a year old, there's fuel in the filter and fuel getting though the injectors. It turns fine just won't fire up no matter how long I try and the weathers always been mild/warm at the time.
If I bump start it, I'm then able to turn the engine off and start it with the key within minutes
I read somewhere it could be something to do with the voltage the starter motor is using? Any advice will be appricatied thanks
