by pepepluisje » Sat May 20, 2017 4:03 pm
hi guys;
firstly im in france and the problem has been looked at in france,
i have a dead van, and will try to explain in as short a description as i can but wont be easy;
i have had the van for 13 years from new, and has been a great workhorse, never using any water, oil stays on the mark between yearly servicing !! changed the front wheel bearings, heater motor, and one power steering issue, and thats it; fantastic example of how a van looks after you if you look after it;;
HOWEVER, the story, i was driving home, all running fine, when i felt a blip in the throttle pedal, just as if it moved a half inch under my foot without me doing anything !! no other sign of anything untoward; it happened twice;
i got home, later that evening i went to drive the van and it sounded louder on tick over than normal ? to the point that i looked at the floor expecting to see a whole where the noise was coming through but of coarse there was not one; but it jut sounded louder , as i let it idle, i revved it slowly and it felt a bit hesitant, and running a little rough and you could feel it through the pedal also;
the more i revved it the more hesitant it sounded along with some unfriendly tapping noises which were intermitant but from where i have no idea;
then i started running rougher with white smoke from the exhaust and under the bonnet !! so switched off with the idea to get it to the garage in the morning
come morning i tried to start it but it would not fire, just white smoke everywhere, the garage came and it did start and still the smoke but it was running an they were revving it quite hard but apart from the smoke, and being lumpy, it ran, they said it might be the egr valve or something like that, and tried to see if it was drivable to get to the garage, but it had no power to pull up the slope of the drive and just chucked loads of white out the back o they collected it on transport
was not a dealer but they done some basic checks, changed the filter took the EGR valve or whatever it called off, but made no difference, checked the injectors and said they were fine !! but didn't really know what it was and suggested it may be the main pump; and shipped the van to a ford dealer,
they had it for two and half weeks, there report was that they did not know the fault, but it may be the main pump and it may not so they dont want to commit to saying one way or another; they also said they wanted to do a compression test but in order to do that, they needed to remove the glow plugs, but one was ok but the other was tight and they were worried about taking it out in case it broke, and if it did they would need to change also the cylinder head; so again they refused to continue any more investigation and asked me to remove the van from their premises !!
i now have the van back at my place, but whatever ford have done during their diagnostic, for want of another word, it will not start at all; it tries to fire now and again but refuses; the same puff of white comes out the exhaust and from a pipe on the right side of the engine, its just a wisp but can clearly be seen
this is a uk bought van not french by the way;
im not up to speed on this type of thing so i cant really check anything, but i am thinking perhaps they have already broken or snapped the glow plug and are trying to cover up, but i dont even know where they are and how to check etc;
i cant imagine at 13 years old and 280.000km on the clock that this van as good as it has been , warrents spending thousands on it ??? but does anyone have an idea what t could be and if i could carry out any simple checks ??
the van was working perfect before the sudden failure
bob
