Ford Transit 1998 Alternator Stolen
Postby Scrambler » Sun May 21, 2017 6:09 am
Hi there I bought a fixer upper camper van with a blown engine but unfortunately some little rat bag has stolen the alternator :roll:
I've finally managed to track one down (bosch) ive got a couple hoses I need for the vac pump but trying to figure out where they go. Here a picture with the outlets/inlets in question circled. Now one must go up to the brake booster? I'm guessing thats the threaded fitting but un sure. Why is this fitting threaded? Also the other one goes to the fitting on the engine just under where the alternator mounts?
https://s22.postimg.org/svkbkit35/s-l500.jpg
Scrambler
Re: Ford Transit 1998 Alternator Stolen
Postby andz327 » Sun May 21, 2017 1:25 pm
Scrambler wrote:Hi there I bought a fixer upper camper van with a blown engine but unfortunately some little rat bag has stolen the alternator :roll:
Think its an oil feed and return hence the threads
andZ3 Sony Z3
andz327
Postby Scrambler » Fri Jun 02, 2017 8:58 am
thanks, is anyone able to just give me a quick diagram or a photo or two of their mark 5 with a bosch alternator? as I can see where the hoses go? Much appreciated
Scrambler
Postby B4ndit » Fri Jun 02, 2017 8:46 pm
will have a look at mine tomorrow for you and take a couple of pic's
B4ndit
Postby robbie.cee » Fri Jun 02, 2017 9:17 pm
Run it up u
If poss and feel which port sucks?!
Sent from my SM-G920F using Tapatalk
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Fri Jun 02, 2017 9:18 pm
Meant run it up... phone added "u" sorry
Had
MAKE IT FIT
robbie.cee
Postby Scrambler » Sat Jun 03, 2017 7:44 am
Thanks Bandit that would be an amazingly huge help!!!
I did run it up when the wreckers gave me the wrong alternator but the oils just pisses out of everywhere so i'd like to avoid that again if possible
Scrambler
Postby Scrambler » Mon Jun 05, 2017 7:39 am
Anyone kindly likely to provide a pic?? Cheers
Scrambler
Postby B4ndit » Tue Jun 06, 2017 6:54 pm
Sorry mate have been busy but will get one tomorrow for you
B4ndit
Postby Scrambler » Fri Jun 09, 2017 7:35 am
B4ndit wrote:Sorry mate have been busy but will get one tomorrow for you
No worries mate sorry for pestering!
Scrambler
