I have a German import 2012 Hymer A class (no seperate cab) motorhome. It is based on a LHD 2011 build Transit 1.7-350L.
VIN No. is WF07XXTTF7BJ29713
When removing the passenger seat I managed to pull off the plug from the airbag sensors on the seat, I've attached a photo. Unfortunately I now have no way of knowing which of the two wires goes into which socket. The colours are brown and light blue/purple stripe on the vehicle harness, and green and light blue from the seat. The seat is an Agutti, not a Ford part
I have been told by a local auto electrician that it doesn't matter which way round the wires go, but bearing in mind they are part of the airbag system I'd like conformation that it doesn't matter. If it does matter then I would like guidance as to which of the two seat wires, green and light blue go the brown and light blue/purple stripe wires attached to the vehicle.
It appears difficult or almost impossible to access the sensors/seat end of the broken cable, so I cant get any guidance there.
I'd appreciate any help with this.
Malcolm
