My 2002 Mk6 280SWB transit was on a customers drive and wouldn't open on the fob and the drivers door lock is jammed so I couldn't open it with that.Nightmare!
So I ended up shorting the wiring loom to get it open but the fob has no effect on the central locking now, I've changed the battery and checked the PCB for shorts or corrosion but it looks ok.
Do you have any idea what I need to do to fix this?
Many thanks in advance
