RPWC wrote:My mk7 won't lock, the door open light is on on the dash but all the doors are shut firmly. When Inpress the lock button or try using the key, the doors just open again and the horn sounds, how do I rectify this.?
andz327 wrote:Sounds like you're on the right track
Did you clean the spring loaded pins
Does the door close enough for contacts to touch
Disconnecting wont do anything as it will think a door is open
Do they lock manually from inside?
andZ3 Sony Z3
