UPFITTER SWITCHES
UPFITTER SWITCHES
Postby FredMcCarter69 » Fri May 26, 2017 11:46 am
I have a TRANSIT van built 1/31/2017
I ordered the upfitter switches from the factory.
I referred to FORD SVE BULLETIN Q-250 to see where the outputs are for the four switched circuits.
It appears they have changed since this document. On the C33-H block I have 1 always HOT out and 1 always COLD out.
The switches nor the ignition change these two outputs.
I believe FORD might have moved them.
Has anyone run across this problem?
FredMcCarter69
