OuterMongolia wrote:After I had an oil change there is way too much oil in the engine ,above the maximum mark .Should I be worried .I lose oil anyway and I am always topping up .Does this increase engine oil pressure dramatically? Should I be worried about damage to seals and gaskets ? I have 1999 2.5 diesel MK5 smiley .Non turbo .
toppetsaha wrote:you could fill that engine up with piss & it would be alright...
ABA wrote:did you switch engine off and give it plenty of time to settle before you dipped the stick
andz327 wrote:OuterMongolia wrote:After I had an oil change there is way too much oil in the engine ,above the maximum mark .Should I be worried .I lose oil anyway and I am always topping up .Does this increase engine oil pressure dramatically? Should I be worried about damage to seals and gaskets ? I have 1999 2.5 diesel MK5 smiley .Non turbo .
How much above? How much did you put in?
andZ3 Sony Z3
