ignition
ignition
Postby WRussellE39 » Sun Jun 04, 2017 10:16 pm
hello all, i have a problem on my 1999 tourneo, when i switch off the ignition the engine keeps running i turn the ignition back on then off and the engine stops, it has a lucas epic pump, i am guessing this has something to do with the fuel shut off, also worried that this method will stop working and then how do you stop the engine short of trying to cut off the air, any help would be much appreciated.
WRussellE39
Re: ignition
Postby Altransit » Sun Jun 04, 2017 11:14 pm
If it's an EPIC pump, then you more than likely have a fault with the ESOS (Electronic Switch Off Solenoid) This will also put the van in limp home mode when it's running.
You can always stall the engine by engaging 5th gear and letting up the clutch (with the brakes on) but the ESOS needs sorting properly :(
Re: ignition
Postby WRussellE39 » Tue Jun 06, 2017 9:30 pm
thanks
for your reply, it has now gone into limp mode, i can't stall it as its an automatic, where is the esos? i presume its on the pump, the pumps are now obsolete so is it renewable do you know? p.s it is a lucas epic pump.
WRussellE39
Re: ignition
Postby Altransit » Tue Jun 06, 2017 9:57 pm
Re: ignition
Postby MinorMatt » Wed Jun 07, 2017 1:11 pm
I can supply plungers if required ;)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: ignition
Postby WRussellE39 » Sat Jun 10, 2017 11:20 pm
hello minor matt, i have found out which one is the esos and am wondering if this is repairable or even better still available for replacement? i had a problem with it before and the code said it was the cam position sensor, in your opinion would this have been the sensor at fault or the sensor indicating a pump fault,
WRussellE39
Re: ignition
Postby Jim Archer » Tue Jun 13, 2017 8:17 am
Which code reader system did you use to get the fault code? Most won't communicate, and those that can usually give false codes - or rather false interpretations. Lucas Laser or Ford FDS the only reliable ones.
There is a cam ring sensor in the pump. Worn cambelt will be the usual cause for most 'timing' errors.
ESOS normally just gives pump control report fault - it knows there's a fault as the motor keeps running when it should shut down, the 'limp home' is the default engine/pump protection option.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: ignition
Postby MinorMatt » Tue Jun 13, 2017 12:36 pm
WRussellE39 wrote:hello minor matt, i have found out which one is the esos and am wondering if this is repairable or even better still available for replacement? i had a problem with it before and the code said it was the cam position sensor, in your opinion would this have been the sensor at fault or the sensor indicating a pump fault,
Cam position sensor does cause limp home mode, however it won't cause the running on you describe. It is likely it is a historic code which hasn't been cleared
I still have plungers available as a replacement. Did you look at the link Altransit posted?
93 L GL Minibus
Re: ignition
Postby WRussellE39 » Tue Jun 13, 2017 10:08 pm
hello again, i did not spot that link that Altransit put on, many thanks for that its a great help, and if you have the plungers MinorMatt i would like to take you up on the offer of them, just let me know how much and how you would like me to pay, many thanks all.
WRussellE39
