MK6 TDCi 2.4 135 - Definitive answer to bleeding fuel system
Postby MickyUK » Fri Jun 09, 2017 2:16 pm
Hi All,
As per title, is there actually a concrete, confirmed way of bleeding these little fookers?! There are so many conflicting suggestions that I have read. Some suggest cracking the injectors. Other say do not as the PCM won't like it. Some say tow it & bump start. Others say do not as the chain is likely to foxtrot Oscar.
Any input would be greatly received!
Many thanks,
Mick
MickyUK
Re: MK6 TDCi 2.4 135 - Definitive answer to bleeding fuel sy
Postby andz327 » Fri Jun 09, 2017 2:22 pm
Fill the new (hopefully gen ford)filter up with fuel, then do a quick swap and you should be good to go, just hold the revs up a bit to it clears tdci should self bleed
andZ3 Sony Z3
andz327
Postby andz327 » Fri Jun 09, 2017 2:58 pm
If your ever going to tow start do it in 3rd gearand just ease the clutch up slowly once moving, or 3rd gear from standing still, just so there's no instant bang and gives a chance for oil pressure to build up through the tensioner
andZ3 Sony Z3
andz327
Postby ned » Fri Jun 09, 2017 7:25 pm
Tdci is self bleeding, fill fuel filer and start the van after a few minutes idle it should be fine.
NEVER CRACK THE INJECTORS OPEN to bleed a tdci, its a high pressure system.
Why do you need to bleed it have you ran out of fuel?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ake » Sat Jun 10, 2017 7:46 am
Cracking the injectors causes low pressure in the fuel rail, which means the pcm sees a fault and so stops trying to inject
As said if you must tow start, third gear, and don't touch the clutch, the 135 is the worst for timing chain jumping.
If it has run out of fuel, remove filter, fill with fuel, refit, crank for 30 seconds, remove filter, fill with fuel, refit, crank for 30 seconds, repeat until it starts
Postby MickyUK » Thu Jun 15, 2017 1:09 pm
Hi All, thanks for all of the replies. Chain had jumped. Head replaced with matching carrier etc.....
No faults showing. It's nearly there on crank, just being a b*stard to fire!
MickyUK
Postby ned » Thu Jun 15, 2017 6:03 pm
Try a touch of sleazy start. N
ned
Postby knobby1 » Thu Jun 15, 2017 11:02 pm
nedforceone wrote:Try a touch of sleazy start. N
+1^^ yep...give her a sniff of easy start or "start ya b*stard" and you should be good to go.
