by knobby1 » Wed Jun 14, 2017 3:02 am
P1248 = OBD-II generic code for the engine control module (ECM) detecting the fuel injector group A supply voltage circuit has a high resistance causing a short in the system.
What causes the P2148 code? (Stolen from the interweb..!)
"The ECM monitors the voltage supply circuit to the injectors and if the circuit has a high resistance like a shorted injector or harness for the A group of injectors then the code will be set and the Check Engine light will be turned on. This code is for an engine that has supply power to the injectors in two different banks of injectors instead of all injectors on one power supply. This code is for bank A shorted."
My guess is that you still have a wiring issue. FWD's often have loom issues where the loom goes over the starter motor. You may have to peel the outer cover off an check all the wires etc...
