MK7 2.2 problems
MK7 2.2 problems
Postby northernlad » Mon Jun 12, 2017 9:24 pm
The Gearbox on my transit went, so we took it out and had it rebuilt . We put the gearbox back in and started the engine, left it running for 10 mins, came back to it, and it had spat all the engine oil out of the exhaust.
We put fresh oil into the engine, it cranks over and sounds as if it has compression, but won't fire ?
Any ideas.
northernlad
Re: MK7 2.2 problems
Postby andz327 » Mon Jun 12, 2017 9:39 pm
Pull pipe off the turbo and check impeller for breakage, very loose as that's usually the fault when oil is dumped into exhaust, unfortunately the timing chain tensioner works by oil pressure and if its ran dry it's sounds as though the chain has lost tension jumped teeth and snapped when pistons hit the valves
andZ3 Sony Z3
andz327
Postby Punto443 » Mon Jun 12, 2017 9:42 pm
From that little story, I'd say a faulty turbo sucked up all the oil and blew it out the exhaust.
That can be terminal in a lot of cases.
Can't see why else it would have done it?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby andz327 » Mon Jun 12, 2017 10:47 pm
Punto443 wrote:From that little story, I'd say a faulty turbo sucked up all the oil and blew it out the exhaust.
Isn't that just what said
andZ3 Sony Z3
andz327
